-   -   Reuse Mud Bed or Replace with DuRock? (http://www.diychatroom.com/f5/reuse-mud-bed-replace-durock-187948/)
rtastad 10-02-2013 04:32 PM
2 Attachment(s)
I am new to the site and new to flooring. We are putting a combination of 20*20" and 13*13" tiles in our entry way. I removed the existing small tiles that were laid in the mid 70's and am wondering how I should proceed.
Do I add a leveling agent over the existing material, or do I remove it down to the subfloor and add durock?
The subflooring is 3/4" plywood over 2*10 joists that are 16 inches apart.
I've attached a couple pictures to give you an idea of what I'm looking at. My gut tells me that I'll need to rip this up and start over, but I don't want to do any extra work if there's little/no benefit.
rtastad 10-02-2013 06:57 PM
So a little more research confirmed that I needed to remove the "Jersey" whatever (mortar bed with mesh inside). I've started this process; it's definitely not fun or easy.
Will I need to add a layer of plywood? If so, 1/2 or 3/4". Again the existing construction is 3/4" plywood over 2*10 joists that are 16" on center.
Thanks.
JazMan 10-03-2013 09:22 PM
Hi,
I answered at your other thread and thought it seemed familiar.
One question for you, does this area and the kitchen in the other thread meet someplace?
BTW, that is not a Jersey Mud job. That is a standard mud job.
I would think you'd want to be at the same level as the other room. If so, add 3/4" ply then your 1/4" Durock, if that's what you're using.
Jaz
rtastad 10-03-2013 09:56 PM
Same house. (Big project...)
The other thread is my kitchen. This is the entry on a split foyer house. So no need to correspond with another floor level. I have removed half of the cement so far and will drop some 3/4" plywood and Durock when ready.
