Reuse Concrete Board - Flooring - DIY Chatroom Home Improvement Forum
Old 10-05-2011, 09:41 PM   #1
Reuse concrete board
Is it possible to remove older tile and replace with new tile using the same concrete board. Will the concrete board need to be replaced ? Will it become smooth enough to use again?
jat123 is offline   Reply With Quote
Old 10-05-2011, 10:04 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Is it possible?
Yow it could be.
Is it likely?
Nope.
That is anybodies guess.
Old 10-05-2011, 10:11 PM   #3
Rewards Points: 150
No...
OhioHomeDoctor is offline   Reply With Quote
Old 10-06-2011, 08:41 AM   #4
DIY staff
Rewards Points: 7,174
At $9.00 a sheet i doubt if any one with any common sense would ever find out.
I
What tool to cut concrete board with humberguy Building & Construction 2 06-25-2011 11:28 PM
furring strips or 2x4s against concrete basement wall? denemante Building & Construction 15 01-28-2011 04:49 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 02:56 PM
Concrete over foam board Mudball Building & Construction 16 01-11-2010 11:03 PM
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 10:38 AM
