REtrofitting A Wall On Top Of Laminate Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 05-09-2013, 02:37 PM   #1
Rewards Points: 57
REtrofitting a wall on top of laminate flooring
I have a finished basement with a floating laminate floor throughout.
The layout is a rectangle
I'd like to section off the end of it to create a separate room.
The easiest way I think would be to use the existing 3 walls - so I'd just need to add 1 wall from side to side (leaving door opening)
Being that the laminate is already there, I don't want to build a wall on top of it and have the laminate buckle
What do you suggest?
cgott42 is offline   Reply With Quote
Old 05-09-2013, 04:42 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,790
Just cut the laminate "sole plate" out with a circular saw/ossilating saw?
MTN REMODEL LLC is offline   Reply With Quote
Old 05-09-2013, 05:45 PM   #3
Rewards Points: 57
Thanks - I forgot to mention, that there's a decent chance that a few years down the road, I'll want to do away with the wall - so a wall I can take down, but don't want to leave a bare strip on the floor.
Old 05-09-2013, 05:55 PM   #4
Rewards Points: 14,312
You have no choise on this one.
That type flooring needs to be able to expand and contract or it's going to buckle.
Not a great choise of flooring for below grade anyway so not much to loose.
Old 05-09-2013, 06:13 PM   #5
CG... Have no idea if this is a utility type room, where quality/appearance does not matter that much, or it needs to look very good.
I can't really think of a way to anchor a sole plate for your wall securily without penetrating the laminate at least minimally.
Maybe you could "glue" it down with either an acrylic or silicon caulk.... pretty flaky idea I know.... and the wall would be floating just as the floor is... and subject to movement out of plumb with any floor movement.
Depending on the wall span (length), you could just scure your end walls securily and let the sole plate float on the floor..maybe thin carpet under it.... probably secure your top plate well to ceiling joist... in effect let it hang.... wouldn't be very sturdy... but maybe it doesn't have to be. Probably frame with screws
Just my best and dumb ideas
Good luck
Old 05-09-2013, 08:30 PM   #6
Rewards Points: 57
Good luck
Thanks that would work -the floating wall- doesn't need to be too sturdy
Old 05-10-2013, 01:51 PM   #7
Rewards Points: 578
Or you could do the easily removable option and get those foldable room dividers. They just stand up on their end and block access. There is also a door called an accordion door, if you found one long enough you could just stretch two of them across the opening and they would join in the middle, hanging from the ceiling.
Come and see the progress on my mobile home paradise!!! (NEW PICS ADDED ON 01/26/15!!)
http://www.diychatroom.com/f49/compl...emodel-168570/
TrailerParadise is offline   Reply With Quote
The Following User Says Thank You to TrailerParadise For This Useful Post:
MTN REMODEL LLC (05-10-2013)
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
removing laminate flooring mikeinMemphis Flooring 24 02-24-2013 09:06 PM
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
What could I do with my inside corners with laminate flooring on wall? yummy mummy Building & Construction 6 01-23-2009 11:20 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
