Retile Floor That Has Vinyl Underneath - Flooring - DIY Chatroom Home Improvement Forum
Old 12-29-2016, 10:45 AM   #1
bryanp22's Avatar
Rewards Points: 288
Retile floor that has vinyl underneath
We are looking at retiling our kitchen floor and we found that a layer of vinyl exists under the tile by looking at a floor vent. The house is from 1943 but it looks like they put 3/4 plywood on top of the original planks and a vinyl was put down at some point. Then they used some type of liquid underlayment that is blue before putting the tile on top.
My guess is I have to remove and replace the subfloor but is that correct?
bryanp22 is offline   Reply With Quote
Old 12-29-2016, 11:01 AM   #2
Rewards Points: 504
Re: Retile floor that has vinyl underneath
Not sure as I can't figure out what layer is in what order from your post but the vinyl and any 1/4" underlayment under it needs to be removed.
stick\shift is offline   Reply With Quote
Old 12-29-2016, 11:21 AM   #3
bryanp22's Avatar
Rewards Points: 288
Here is a photo and the only thing the metal flashing is blocking is the original wood planks underneath the plywood
Old 12-29-2016, 04:42 PM   #4
Rewards Points: 272
If you are going to put ceramic tiles down you will need cement board like Harding backerboard or wunderboard.
Sent from my XT1031 using Tapatalk
Mikeron is offline   Reply With Quote
Old 12-29-2016, 04:53 PM   #5
bryanp22's Avatar
Rewards Points: 288
I know that part. I am more curious how many layers of the old floor I need to remove based upon the above photo
Vinyl Tile over old vinyl? joe14 Flooring 10 08-02-2014 01:43 PM
Have this sheet vinyl floor asbestos tested? CoconutPete General DIY Discussions 11 01-21-2012 11:39 PM
New Vinyl Siding Went From $43k to $15k In A Few Days nycgto Off Topic 12 07-27-2010 12:46 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
