Resurfacing Steps (carpet To Wood) - Flooring - DIY Chatroom Home Improvement Forum
Old 10-18-2010, 12:24 PM   #1
Resurfacing steps (carpet to wood)
Edited for conciseness:
We have crappy, 30-year-old, commercial-grade carpet on our steps (3 flights' worth).
Is engineered wood better than solid wood for this application?
Also thinking about ceramic tiles for the landings (1 on each flight, about 20 sq/ft me thinks). Good idea? Bad idea?
Is it better to buy pre-made stairs that I cut to fit, or is it worth the cost savings to get planks?
What about moulding? Necessary? Will the absence of stringers lead to scratched/chipped paint?
Ok I think that's all. Any helps is greatly appreciated.
oakback is offline   Reply With Quote
Old 10-18-2010, 01:15 PM   #2
jlhaslip's Avatar
Rewards Points: 2,866
One thing to consider is that adding 3/4" of hardwood will change the rise on your treads. The bottom one will become a tripping hazard. It will be taller than the others and particularly noticeable coming down the stairs.
Something I've done is to shim under the second, third, etc treads with 5/8", then 1/2", then 3/8", etc to "feather" the difference out. It isn't right, but the brain senses the steps being similar and reduces the tripping possibilities.
I have made my own treads and nosings from left-over hardwood flooring from a job. Chamfer the nosings and biscuits as joinery method, then round over and coat with a Polyurethane.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 10-18-2010, 01:19 PM   #3
(I edited my first post to more specifics)
What is the typical difference in thickness between wood floor and carpet+padding?
Old 10-20-2010, 09:12 AM   #4
After doing the math, it looks like new 1" treads will increase the step height by 1/4" (over the current carpet thickness). Is this enough to be a problem?
edit: n/m, I'll just go with the shimming idea, I like that a lot.
Changing from carpet stairs to wood stairs DIY_user Remodeling 16 07-29-2010 07:16 PM
Rubber mulch Vs. Kids Carpet mulch for backyard play system whataboutj Landscaping & Lawn Care 1 04-26-2010 10:22 AM
Removing glued on outdoor carpet from concrete steps churchlady Flooring 3 11-30-2009 11:03 PM
Rug on stairs, 1st step wood? Engineered steps? sportinwla Flooring 0 11-25-2009 12:46 AM
Re-staining inside steps saggdevil Painting 10 09-20-2009 06:40 PM
