Old 06-29-2012, 06:04 AM   #1
sdsester's Avatar
Restore Antique Oyster Cracker Floor
I have been asked to bid, for a friend, on restoring a white antique oyster cracker tile floor and it reminds me I promised a friend who owns an art gallery with one I would get around to this ages ago. In the case of the gallery, the name of the original movie theater is in black tiles. You can see how the floor has grayed the photo:
In both cases the tile is over a century old and is just dull and dirty looking. Of course most of the surface in places is eroded but still nice. There are some cracks but the mortar is still holding. I took some oxyclean to tile and mortar in some areas and it worked amazingly well. I am not sure that is the way to go though so am seeking wisdom from those who refinish antique tile floors. I know wood floor guys but not many that take on old tile, marble and so forth.
Who should I call to clean, polish and seal it? It is important in both cases the floor stays as original if possible.
sdsester is online now   Reply With Quote
Old 06-29-2012, 07:34 AM   #2
Super Moderator
O.K.----What is an 'oyster cracker' floor---Google did not help---Mike---
Old 06-29-2012, 08:13 AM   #3
bbo
i'm guessing OP is referring to the shape of the tile
bbo is offline   Reply With Quote
Old 06-29-2012, 08:26 AM   #4
Super Moderator
Ah----Unglazed porcelain--- Strong soap--scrub brush---
Some times they were waxed--so ammonia might be needed-
Some times a mild acid cleaner will help--
Go armed with every sort of cleaner you can think of--and try different areas---
Old 06-29-2012, 12:06 PM   #5
sdsester's Avatar
Yes, that is the type floor I was posting about.
I am not anxious to use an acid but may have too. I want to keep the integrity of the grout.
Once clean, what should I spec for sealing the tile and grout? What kind of maintenance schedule would you recommend? It strikes me that anything waxy would create an ice rink.
Old 06-30-2012, 06:44 PM   #6
Super Moderator
Once you get the tile clean no sealing should be needed--it's porcelain and will not absorb dirt--
However--if the tile is a mat finish it may show scuffs--If you wish to wax it--there are non slip waxes available at any janitorial supply house---
Trouble with wax--it discolors with time and grabs dirt--so doing without is preferred if the tiles surface isn't to rough.
Old 12-09-2012, 10:35 AM   #7
Those hexagon shaped tiles came in a varity of colors including various shades of white, cream, and grey. I'm thinking that those greying tile you want to restore are actually made in a light shade of grey.
Bruntson is offline   Reply With Quote
antique wood floor dltrosvig Flooring 2 06-27-2010 02:55 PM
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 01:11 PM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 05:58 AM
Levelling wood floor gomi_otaku Building & Construction 13 11-27-2008 08:45 AM
Old old linoleum, can it take paint? molamola Painting 23 11-11-2008 07:32 PM
