Resilient Flooring And Uneven Floors - Flooring - DIY Chatroom Home Improvement Forum
Old 12-06-2010, 12:25 PM   #1
resilient flooring and uneven floors
I'm reflooring my kitchen and just picked up some of the trafficmaster ceramica resilient tiles. One of the walls of the kitchen slopes downward a bit. I'm guessing about .5 - .75 of an inch over the 4-5 feet towards the wall. Although the floor seems to slope off in that spot, there is a doorway to an adjoining room at this same spot and If I tried to level it out, it would throw my room transition off (currently the adjoining room sits at that same level).
So my hope is that since the resilient tile is much more pliable than ceramic, that this slight slope will not cause problems. Does anyone else have experience with this type of scenario? Thoughts? Tips?
thanks in advance.
boxy_brown is offline   Reply With Quote
Old 03-06-2012, 02:07 AM   #2
Rewards Points: 53
A friend in Vancouver says that it's pretty good about adapting to slight changes in slope. If it's too much you may have to be clever laying it -- e.g. shave the corners to keep a straight line. If you are laying it without grout, this gets to be a bit more critical.
One trick: If you get one that doesn't quite want to lay down, iron it. The heat will soften the tile enough to bend -- it also makes the glue soften, if you ever need to remove a tile.
sgbotsford is offline   Reply With Quote
laminate flooring on uneven sub floor? ponch37300 Flooring 25 04-06-2013 10:29 PM
Uneven Floor Edge for Laminate Flooring sgk Flooring 1 06-21-2010 06:23 PM
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 01:20 PM
Uneven cement flooring, need to put something "soft" on top for mother in law..? andsoitgoes Flooring 13 05-31-2009 10:51 AM
Wet basement, uneven floor - what's the best flooring? pepsigirl Flooring 1 05-16-2009 07:36 PM
