Require Help - Flooring - DIY Chatroom Home Improvement Forum
Old 05-20-2011, 10:09 AM   #1
Require help
I have one small front room which needs to resurfaced with a
wood or laminate.flooring .One half of the subfloor slants .
How do I level the floor as I install the new floor ,with shims?
Gorwood is offline   Reply With Quote
Old 05-20-2011, 11:55 AM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 54
Wood or concrete subfloor?
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
does my furnace require 240 volts to start/run? MLMIB HVAC 1 02-05-2011 08:34 AM
Metal shed require vapour barrier? Mark Harvey Building & Construction 1 01-07-2011 07:25 PM
Does your job require a permit? housedocs General DIY Discussions 203 12-01-2010 08:28 AM
Does code require floor drain for water heater? Quickdraw Plumbing 1 05-21-2009 07:29 AM
What to expect the Inspector to require? jamiedolan Electrical 6 01-12-2009 01:40 PM
