#1 |
Replacing wrong color grout - 900 SF of tile
I just had 900 SF of 18" porcelain tile installed and they used the wrong color grout. It is bright white and was supposed to be light tan (Tec - pearl), which is very similar in color to the tile. I wanted the grout to blend with the tile for a uniform look, but instead it looks like a checkerboard. Is it possible/practical to grind out the existing grout and re-grout with the correct color? The same problem occured on the kitchen backsplash as well. Thank you.
#2 |
K&B Remodeler/Tile Guy
Lonidier, that's A LOT of grout to remove. It's a very messy job. I'd vote a big NO for that choice (unless the contractor will do it at no charge)
![]() A less costly and messy solution would be a grout colorant. It's like staining the grout: http://www.aquamix.com/products/pg_d...5042&pgid=8374
Angus To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by angus242; 07-17-2008 at 11:41 PM. |
#3 |
Thanks for your reply. Are the grout colorants permanent, or do they need to be re-applied periodically? I have not made the final payment to the tile company yet.
#4 |
It's as permanent as it can get. Grout on a floor will get dirty but the color itself shouldn't fade. Actually, the colorant acts as a sealant to the grout itself. It's not a bad option.
Before you make any decision, talk with the contractor to see what they offer as a solution.
Angus To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#5 |
Forgot to mention - I already sealed the grout, using Aqua Mix Sealers Choice Gold. Would that prevent the grout colorant from working?
| Display Modes | |
| Tile over Tile ?? | Piney | Flooring | 17 | 02-06-2012 10:59 PM |
| Replacing 12" ceiling tile with drywall | housefixin | Remodeling | 5 | 09-09-2007 04:00 PM |
| Tile and laminate, or get rid of tile? | kfoster | Flooring | 10 | 03-17-2006 03:14 PM |
