Replacing A Wood Laminate Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 10-22-2011, 03:19 PM   #1
Replacing a wood laminate floor
Too much damage to repair and will not be lifting the floor off. I have been told I can tile over it instead.
The steps I have are these:
Sand the top layer off and then clean the floor and wash it and wait until it's dry.
Roll out latex contact cement and wait until it's tacky to the touch.
Put a little of the cement on the back of the tile, put it into place and press down hard.
Continue until the floor is done.
tarmagon is offline   Reply With Quote
Old 10-22-2011, 03:40 PM   #2
DIY staff
Rewards Points: 7,174
Are you talking about vinyl tile? On top of a floating floor? Never heard of that---I think the movement of the floating floor will telegraph the seams through the vinyl tile.
Old 10-22-2011, 04:39 PM   #3
No it's not a floating floor. It's just cheap wood laminate tiles that someone laid on top of the other flooring tiles. The manager prefers I just tile on top of the old tile.
Old 10-22-2011, 05:09 PM   #4
DIY staff
Oh, Sounds like a rental---If they are stable and not moving--then I think you are O.K. if you sand the finish to remove any wax or high shine.
This is not the best method for a new floor--but you already know that---Realizing that the new floor covering is a short term covering--Go for it!---Mike---
Old 10-22-2011, 05:34 PM   #5
How is your floor height?
It's real easy to raise the floor height enough to lock in your dishwasher or other undesireable outcomes when your 3 deep. Ask me how I know.
weehooker is offline   Reply With Quote
Old 10-22-2011, 07:19 PM   #6
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 182
You are going to have too much adhesive down. Don't put any on the back of the tile. And the adhesive you put on the floor needs to be dry to the touch, not tacky. And if you put the tile adhesive on with a roller, you will get too much. It needs to go down with a 1/16x1/16 trowel. If you get too much down, you will have a real mess.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Squeaky laminate floor on top of leveled wood subfloor macgraffix Flooring 1 12-12-2010 07:09 AM
Is my wood laminate floor installed correctly? sljacobs Flooring 3 09-18-2009 04:15 PM
Levelling wood floor gomi_otaku Building & Construction 13 11-27-2008 07:45 AM
