Replacing Wood Floor Over 1"x4" In Tar Underlayment - Flooring - DIY Chatroom Home Improvement Forum
Old 01-04-2012, 08:42 AM   #1
Replacing Wood Floor over 1"x4" in tar underlayment
Wood floor tongue and groove was nailed over a concrete slab (now leveled) onto 1x4 screeds encased in tar. Had to take all up due to termites. Want to go back with used flooring or tile. For wood flooring: is a floating underlayment advised? If so then how is this done? Materials to use? Must it be anchored to the concrete? What about a vapor barrier (painted or plastic) ? Would anything have to be glued down?
For tile: ?? What sort of slab prep?
waterlevel is offline   Reply With Quote
Old 01-16-2012, 08:05 PM   #2
Any Floor Experts out there?
Hey folks my original question boils down to putting down to a tongue and groove floor going over a concrete slab. How do I do it? No responses thus far...
Old 01-16-2012, 08:34 PM   #3
DIY staff
Rewards Points: 7,174
The reason no one answered is that it is not a recommended surface to put solid hard wood over--
Someone will help--but that's an odd ball---need a hardwood flooring pro--and there are only a few here---Give them time to check in---Mike---
waterlevel (01-31-2012)
Tags
tar embedded screeds
Considering replacing playwood subfloor, many questions. gante Flooring 3 04-12-2010 11:39 PM
Replacing rotten wood under linoleum bathroom floor tryingitourselves Flooring 1 08-21-2008 11:27 AM
Replacing Porch Column base, what wood to use? Shamus Building & Construction 7 05-31-2008 12:29 PM
replacing wood support beam with steel? elementx440 Building & Construction 1 02-15-2007 06:56 PM
Replacing Wood Panel 4'x8' Siding Chevmann99 General DIY Discussions 5 10-02-2005 07:43 PM
