Replacing Tile Floor In Shower - Flooring - DIY Chatroom Home Improvement Forum
Old 06-05-2009, 05:24 PM   #1
Replacing Tile Floor in Shower
First, great forum with thoughtful answers. I appreciate your advice to a newbie.
Replacing the floor of a 1995 tile shower. This is just a tile replacement: the pan is tight with no leaks.
I've removed the ceramic tile, and I'm left with a sloped white thinset and mortar bed surface. Of course, removing the tile scarred up the surface of the mud and left layers of thinset in places. Pretty rough in places. Also, some cracks in the mud from the fun of removing the tile.
Question is, what can I use to re-smooth the surface so I can tile on it? Ideally, I'd like to fill over the thinset and the mud, and not have to remove any more material. Slope is OK (1/4"/ft) so what I need is something that'll help me recreate a good clean surface for new thinset.
Thanks!
banglenot is offline   Reply With Quote
The Following 3 Users Say Thank You to banglenot For This Useful Post:
John DiPalma (09-21-2011), Jsavoy (04-30-2012), mbaker470 (01-15-2012)
Old 06-09-2009, 09:53 AM   #2
LeviDIY's Avatar
Rewards Points: 252
I figured I'd buzz this question up a bit, as I'm curious too... always seems like this step is glazed over when watching some shows or reading about people's reno's...
LeviDIY is offline   Reply With Quote
Old 06-09-2009, 10:55 AM   #3
Thanks, guys -- used the advice on the mortar and now have a smooth bed to lay down tile.
Also confirmed the layout of the liner and the weepholes.
Again, thanks.
tbentley is offline   Reply With Quote
The Following User Says Thank You to tbentley For This Useful Post:
carolwood (03-21-2015)
Old 05-23-2010, 08:43 PM   #4
I would like to know about this one too. I'm working on almost the same project right now. I actually had more of the thinset come up (along with the mortar). Can I smooth out the surface to place new tiles? What material can I use to smooth out the surface? New mortar mix?
JayReeH is offline   Reply With Quote
Old 05-23-2010, 11:27 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Modified thinset mortar.
XXX
Old 05-21-2011, 06:03 PM   #6
I've tiled a floor and backsplash but redoing the shower in my masterbath has me a little concerned. Are you saying that if you can remove the old floor tile in the shower without tearing up the thinset I should be able to simply install the new tile over the old thinset?
dacstephens is offline   Reply With Quote
Old 05-21-2011, 06:20 PM   #7
NACE Coating Inspector
mustangmike3789's Avatar
why disturb the existing tiles, they make a great substraight for new tiles. i would just add an extendo drain and tile over the old tile.
mustangmike3789 is offline   Reply With Quote
Old 05-21-2011, 06:33 PM   #8
DIY staff
Rewards Points: 7,174
If that solution is not to your taste, try Ardex Feather Finish--
The drain set in your shower is adjustable--the top part that you see can be screwed up or down if your tile is a different thickness--
Also,square drain covers are available in different finishes.---Mike---
Old 05-21-2011, 11:39 PM   #9
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
How old is your shower? Any issues such as loose tiles or spongy walls?
I'm no expert, but when I retiled my shower last year and I pulled out the old walls I found soggy, moldy greenboard underneath, not to mention some rotting wood. I don't know if what you are asking could be done or not, but I would want to be absolutely sure there are no issues with the pan or walls before I would even consider it. The older the shower, the more I would be concerned.
Old 05-23-2011, 09:05 PM   #10
Replacing Tile in Shower
Shower is about 13 years old. No loose tile or missing grout. No cracks, sign of damage. Just dirty and "outdated." Also, walls are single sheets of cultured marble. again, no damage, cracks, signs of leaks, etc.
tile man used mastic glue on entrance to shower keyesww Tiling, ceramics, marble 13 06-08-2010 04:39 PM
Shower tile specifics re: hair coloring Pammylu Tiling, ceramics, marble 4 06-05-2009 02:32 PM
Turning a tile shower into a one piece shower... chimera Remodeling 12 03-14-2009 02:30 PM
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 09:11 AM
