Old 07-30-2012, 09:09 AM   #1
Replacing subfloor under a stud?
I need to remove and repair area of subfloor that goes under a stud. What is the general consensus on the technique involved here.
MikeVila is offline   Reply With Quote
Old 07-30-2012, 09:12 AM   #2
Most often I use a Toe Kick saw and cut along the bottom plate, leaving the subfloor under the plate.
In a pinch you can cut it out along the plate with an ossilating saw or a sawsall with a short wood cutting blade.
Why does it all need to come out?
Old 07-30-2012, 12:39 PM   #3
Don't know for sure if will have to come out.A cool leaked all over floor and went unnoticed and continued to do so. Some black mold in corner.
Old 07-30-2012, 12:42 PM   #4
Post a picture. In most cases just some mildicide will take care of it. A lot depends on just how big an area it is.
32" tub replacing 30" tub.... CharlieR Plumbing 7 03-09-2012 09:51 AM
When to replace rotted stud vs. epoxy ken57 Building & Construction 4 11-08-2011 07:48 AM
Toggle bolt through stud? djgrant Carpentry 16 09-25-2011 07:41 PM
Steel Stud Device Box Installation tjames Electrical 3 09-15-2011 12:30 PM
How to butt wood stud wall to steel stud wall? Yorkergizer Building & Construction 3 12-01-2007 01:28 AM
