Old 04-27-2007, 07:34 PM   #1
Unhappy
Replacing a subfloor
I am replacing the subfloor in a bedroom in my home. My home is on a crawl space. I have cut removed the floor and subfloor and have had to replace some of the floor joists. I am in the process of reinstalling the new flooring. I have cut out the floor and subfloor as close to the walls of the room as possible, however, I still have a gap between the new flooring and the wall. I am not sure of how to fill in the gap that now exists between the floor and the wall. I have considered wood putty but I am concerned as to whether or not it will support carpet tacks since I plan to reinstall carpeting in the room. Advice anyone? Thanks in advance.
miami vice 25 is offline   Reply With Quote
Old 04-27-2007, 08:28 PM   #2
jproffer's Avatar
I don't think I'm following you completely.
You cut out the old subfloor (I assume with a circular saw), which would naturally leave about an inch of the old subfloor next to the wall, and that would be fine.
Now you're putting in the new subfloor....(here's where ya kinda lost me). Why do you have a gap?
Just butt the new against the old and screw it down.
OK, so I'm pretty sure that's not your problem or question....so enlighten us and we'd love to help.
jproffer is offline   Reply With Quote
Old 04-27-2007, 09:50 PM   #3
I guess I am overthinking it. I am concerned about the gap between where I cut the old floor out with a circular saw and the wall area. I wanted to know if this area should be filled in with wood pieces or somthing else.
Old 04-27-2007, 11:50 PM   #4
jproffer's Avatar
Is the new subfloor thicker than the old or something?
or
Do you mean the gap that may have been caused by not having a perfect cut on the old subfloor?
I still don't understand...I'm sorry.
Old 05-01-2007, 03:12 PM   #5
Your diagram was very helpful. Thank you. Where did you get the software to do that diagram? The situation I have is that when I cut out the subflooring the edges of the new subflooring are not flush with the edge of the old subflooring that I cut out. I guess I need to retrim the edge of the subfloor that I cut out to make it flush. But even then I will have a small gap between the edge of the old subflooing and the new subflooring. I was under the assumption that I would have to fill this gap in with some thing. But I guess the gap will be covered when I drywall and add trim to the walls of the room. Suggestions?
Old 05-01-2007, 03:36 PM   #6
Vice, we REALLY want to help, but I can't for the life of me picture what you're working with. Can you post a picture???
moneymgmt is offline   Reply With Quote
Old 05-01-2007, 04:52 PM   #7
Sorry...I will start with the basics. I removed the subfloor in the bedroom of a home that sits over a crawl space. When I lay the new subfloor down and attempted to make it flush or lineup with the subflooring that I did not cut out there is a gap between where the old subfloor and the new subfloor line up. I sent a drawing and the red area represents the new subflooring and the black area represents the old flooring area. Does this help?
Old 05-01-2007, 05:37 PM   #8
not a total Newbie
What size gap are we talkin'?
Does the new subfloor meet the old subfloor (i.e. "break") on the center of a joist?
space_coyote is offline   Reply With Quote
Old 05-01-2007, 05:54 PM   #9
The gap between the new subfloor and the wall is about 1/2 inch or less. The new subfloor meets at the center of all the joist so that is not a problem. I do not have a concern with a gap in the center of the floor just near the walls. Did my drawing help?
Old 05-01-2007, 06:21 PM   #10
What is recommended to secure the new subflooring nails or screws? What type? How long considering I am replacing roughly 2 inches of flooring.
Old 05-01-2007, 10:29 PM   #11
jproffer's Avatar
Do you mean vertically?
OK, if you layed down ON the floor...with your eye ON the floor, would it look like this diagram (see below) from the side? Looking along the line between the old and the new...a gap that way??
If so then NOW we're getting somewhere.
If that's the case, you'll have to fill that in with something. How wide of an area is this...horizontally? How close to the wall?
I'll also say this, if this helps: The first nail that would actually be INTO the floor will be a good 1 - 1.5 inches away from the wall framing.
Also, in case I'm lost totally again...pictures would be a great help.
Also: What do you mean you're replacing 2 inches of flooring???
More On This Topic
Replacing your windows is one way to boost the value of your home, especially if the new windows are more energy efficient. One of the popular styles of replacement windows is vinyl retrofit replacement windows. Read this eHow to learn how to trim... Read More »
I'm Tom Shean and today on behalf of Expert Village I'm going to show you how to install a metal roof. The shake panels are terminated by bending over the gable fascia at approximately 2 inches. Place the shake cap over the gable aligning a profile in... Read More »
Hello my name is Sabirah Parker I am one of the owners of Beadalicious located at 34 East Landgo Street in Baltimore, Maryland on behalf of Expert Village I like to welcome you back to creating beaded jewelry. We will continue with segment five flush... Read More »
Hi, this is Sean Hobson for Expert Village. What we want to talk about right now is the importance of the linebackers knowing their gap responsibilities. Now the linemen also have some gap responsibilities as well, and I'm going to hit on those as well... Read More »
Hi, I'm Mich for Expert Village. Continuing with our presentation, now I'm going to show you how to make a diagram. You go to insert, you open it and diagram. Here are different types diagram, but we're going to use this pyramid. Click o.k. and here you... Read More »
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 07:29 AM
BAthroom Subfloor Blaze25 Flooring 3 11-17-2006 10:06 AM
subfloor for laminate and tiles mf915 Flooring 10 05-18-2006 05:01 PM
COMPLETE subfloor removal alexschmidt Flooring 4 08-03-2005 12:15 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
