Replacing Sub-flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 08-10-2010, 06:07 PM   #1
replacing sub-flooring
We live in a colonial home that is 25 years old and all the floors squeak. We were thinking about replacing all the sub-flooring and re-carpeting the new floors. What do you recommend for this problem?
brenda fields is offline   Reply With Quote
Old 08-10-2010, 06:17 PM   #2
Rewards Points: 282
There are much easier and more cost effective solutions for squeaky floors than replacing all the subfloor. There are special screws calledd Squeek no more http://www.amazon.com/Berry-Enterpri.../dp/B0006IK8YE that will fasten down a subfloor right throught a carpet. You can shim the subfloor underneath. There are a lot mor solutions depending on the cause and source of the squeak.
Jim F is offline   Reply With Quote
The Following User Says Thank You to Jim F For This Useful Post:
oh'mike (08-10-2010)
Old 08-10-2010, 08:21 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 388
There is no reason to replace the subfloor unless it got flooded, even then it may not be necessary. Your subfloor needs to be fastened, it's moving up and down and that is the sound you hear.
Heck, I've even used finish nails into the carpet and pad once before the special break-off screws. Squeak No Mor works if you're keeping the carpet, otherwise rip the carpet and pad, then use flooring screws which are much cheaper.
Jaz
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 06:37 PM
Replacing torn up Linoleum flooring rippedupfloor Flooring 0 06-09-2010 02:38 PM
Strange engineered wood flooring install in Philippines (pics) Flt_Simulation Flooring 7 10-05-2009 09:00 AM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 11:32 AM
