Replacing Slat Subfloor - Flooring - DIY Chatroom Home Improvement Forum
Old 12-04-2012, 06:41 AM   #1
Rewards Points: 4,796
Replacing slat subfloor
Replacing part of an old subfloor in a kitchen due to water damage. Old floor is 1x6 wood slats with plywood on top. Is there any benefit to replacing with slats again? I can't think of any myself, and would replace with T&G plywood. Slats vs. plywood vs. OSB to replace the slats, then another layer of plywood on top of that. I don't know that full thickness of the slat layer plus plywood layer, but if it is 1 1/4" total, I suppose a single thick layer of plywood could replace the slats plus plywood that's being replaced. (The final surface will be tile, so Ditra or cement board will be the top layer.)
jeffnc is offline   Reply With Quote
Old 12-04-2012, 07:41 AM   #2
Rewards Points: 13,724
I would use 3/4 T X G Advantec with constrution adhesive on the joist, instead of plywood. There's little squares printed right on the panels to show where it needs to be nailed.
Advantec if far more stable, stiffer, and way more moisture resistant then plywood.
Make sure whatever plywood you use as an underlayment is subfloor rated.
That underlayment is going to have to be nailed every 4" on the edges, and every 6 to 8" in the field., it needs to not line up with the seams below, and not be nailed into the floor joist.
Subfloor and P-trap for basement bathroom svaic00 Plumbing 9 10-11-2012 12:51 PM
Vinyl flooring over wood slat subfloor Patricia54 Flooring 6 02-11-2012 02:22 PM
Replacing Subfloor whatispunk Flooring 1 09-01-2009 09:50 PM
replacing subfloor milkman7979 Flooring 4 06-05-2008 09:41 PM
Replacing a subfloor miami vice 25 Flooring 10 05-01-2007 09:29 PM
