Replacing Shower - Flooring - DIY Chatroom Home Improvement Forum
Old 11-13-2006, 12:19 PM   #1
Replacing Shower
All,
I have a serious leak in my 2nd floor bathroom due to a bad tile job in my shower. I have ripped all of the tiles out and am down to the joists/ studs, and plumbing. I plan on installing the following: 7/8" plywood screwed into the joists, 3/4" plywood on top of that, a 1/4" layer of thin set, and then screw in hardy board let sit for 24 hours then tile.
My question is should I be adding some sort of rubber membrane somewhere in the process? If so, how would I go about doing so. Secondly should i be using hardyboard for the walls and cieling and just screwig it directly into the studs? Finally do you have any important tips or reccomendations?
Thanks,
Jack
jackco711 is offline   Reply With Quote
Old 11-14-2006, 09:32 AM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
DUPLICATE POST
See other thread!
Replacing a fiberglass shower Proulx06 Remodeling 11 06-20-2008 04:50 PM
Replacing Shower Fixture RTBTK Plumbing 1 07-27-2007 05:35 PM
Shower head not working, having trouble with replacing the tub spout keyser soze Plumbing 26 06-12-2007 07:39 PM
Replacing damaged shower wall tiles kevind Flooring 4 11-20-2006 12:18 PM
Replacing damaged shower wall tiles kevind Remodeling 3 11-15-2006 10:36 PM
