Replacing My Subfloor - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-15-2008, 01:32 PM   #16
Originally Posted by JazMan View Post
Dan,
That's it, how else would you do it? Remember though that plywood is thinner than its stated thickness by 1/32". You may need to install a few sheets of tar paper first? Af course be sure to use "subfloor" plywood first then you can go with underlayment on top.
Jaz
If I do two layers of plywood, should I do one layer against the joists, and one with the joists, or both against the joists?
DanBress is offline   Reply With Quote
Old 02-15-2008, 06:13 PM   #17
Tileguy
JazMan's Avatar
Rewards Points: 422
Plywood is ALWAYS installed perpendicular to the joists. Make sure you offset the seams. Be sure to fasten the top sheet only to the subfloor. Do not fasten the top sheet to the joists. Don't forget the proper gaps between sheets and also around the perimeter.
BTW, the subfloor should also be glued to the joists. The underlayment is NOT glued to the subfloor.
Jaz
Old 02-16-2008, 09:11 AM   #18
Jaz
What do you mean by "proper gaps between sheets"? If I use T&G wont the sheets lock in with one another?
How much room should I leave around the perimeter?
So, I will fasten the bottom sheet to the joists with glue AND screws. But how should I fasten the top sheet to the bottom sheet?
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 06:29 AM
Replace subfloor? BigJimmy Building & Construction 2 01-13-2008 02:18 PM
Replacing a subfloor miami vice 25 Flooring 10 05-01-2007 09:29 PM
COMPLETE subfloor removal alexschmidt Flooring 4 08-02-2005 11:15 PM
