Replacing Laminate In The Middle Of The Floor! - Flooring - DIY Chatroom Home Improvement Forum
Old 01-22-2008, 11:44 PM   #1
Replacing laminate in the middle of the floor!
Hi guys, I'm hoping someone can help.
First, the picture...
The floor is a laminate floor. There used to be an island in the area where the hammer and hole is located but, I didn't have enough planks to replace/cover the area where the island used to be, so, I shifted some planks from the wall and patched up the wall area. My problem is that there is one plank with part of the plank missing/cut out (to make room for the island.) I have exactly 1 full sized plank left and need to somehow patch this area up. I was wondering if someone knew how to go about replacing a section of a plank and still keep the tongue and groove sections on the sides whole?
As this is going to be a partial replacement, I will not be able to secure the top and bottom part of the plank via tongue and groove. Just the sides.
As you can see just below the hole, there are some examples of planks where the bottom and top tongue and grooves are nonexistant as they were cut off to make room for the island.
It's going to look crappy, but I was thinking of putting putty over the gaps as well...
Anyone have any experience doing this???
greenlake is offline   Reply With Quote
Old 01-23-2008, 11:36 AM   #2
anyone???
Old 01-23-2008, 11:49 AM   #3
Remove the damaged piece without damaging the edges of the surrounding pieces.
Take your new piece, and cut the bottoms of the groove-ends off. Then put a thin bead of glue on the exposed tongues of the existing pieces. Slide your new piece's tongue end into the groove side of the existing floor until it clicks in. Lay the new piece down onto the tongues with glue on them, and weight the new piece. Wipe off any glue squeeze out.
Let it set up for a couple hours.
NateHanson is offline   Reply With Quote
Old 01-23-2008, 12:16 PM   #4
Thanks!
Laminate Floor Install - Advice? cmvsm Flooring 18 07-02-2013 01:18 AM
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Water damage below laminate floor ediconu Flooring 10 01-23-2012 12:19 PM
laminate floor vs subfloor 4 railing mount gdub Flooring 4 01-04-2008 02:42 PM
Horizon Laminate Floor from China Kelvestto Flooring 3 09-19-2006 11:19 PM
