Old 07-02-2012, 02:05 PM   #1
Replacing hardwood over asbestos tiles
I am planning to remodel my kitchen. Right now, the floor is hardwood but it's not in great shape. The kitchen was remodeled some time in the 80s. Under the hardwood is a 9x9 linoleum tile floor which is surely original (1962) and I figure probably contains asbestos. The rest of the house has hardwood that's in much better shape and the kitchen hardwood is about 3/4" higher than the rest of the house.
Question 1: I want to do most of the demo work and whatnot myself. Is it safe for me to take out the hardwood since its over top of the old tiles? For example, are there nails that I'll end up pulling out that go through the tiles that could release asbestos into the air?
Question 2: Can I put anything over the linoleum without removing it? Obviously carpet would work, but not in a kitchen. I would think ceramic or stone tiles would be a no-go without ripping out the orig. floor. Could put new wood down, though I really would like to overcome the flooring height difference with whatever I end up doing.
Question 3: Also, The kitchen is <200 sq. ft. What might be the approx. cost to remove the asbestos containing material if I hire someone?
Thanks!
Scott
scottfs is offline   Reply With Quote
Old 07-02-2012, 02:15 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Unless the asbestos becomes friable, it's not dangerous. Why not replace the hardwood with engineered wood? It's normally thinnner than hardwood and might be the height you want.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 07-02-2012, 02:23 PM   #3
Well, my first choice is I wanted tile. But if it's going to be too expensive as a result of removing the old almost-surely-asbestos-containing tile then I might want to think about something else.
The thing I have against engineered or even real wood is it might look silly abutting the good hardwoods at the edge of the kitchen and wouldn't match. I think tile next to the the hardwood would be ok but two mismatched wood products would probably look odd.
seal asbestos floor tiles. HELP aebloz Flooring 2 12-06-2011 05:25 PM
Replacing tiles titan7 Flooring 1 04-20-2011 06:27 AM
removing asbestos tiles with a heat gun MLMIB Building & Construction 3 03-31-2011 08:51 PM
Asbestos tiles under carpet Sam53 Flooring 2 01-22-2011 09:37 PM
Replacing A Few Tiles On Shower Wall EDENO Remodeling 1 12-11-2006 12:25 PM
