Replacing Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 09-14-2012, 02:25 PM   #1
replacing flooring
I am replacing carpet flooring in DR, LR and formal LR (downstairs office for us) with hardwood. The kitchen makes the "4-corner box", which is already tile.
Unfortunately, I discovered that my front door frame had been leaking following some violent storms awhile ago (long story end result rotten foyer floor) and I will be forced to replace that hardwood.
There are differing opin. about whether I should make all of the space (excluding the tile kitchen) hardwood, for a uniform-continue appearance or replace the foyer hardwood with Travertine..
Opinions?
floor plan is [Dining Room]-[Foyer]-[Office Room]
[Kitchen Tile]----------[Living Room]
thanks
fmrp is offline   Reply With Quote
Old 09-14-2012, 02:56 PM   #2
Travertine...don't even have to think about it for a split second.
I see it all the time and it looks great. I've seen a lot of really classy homes that have travertine at the entrance and it transitions to hardwood beautifully.
I have hardwood extending to the door. Wet slushy boots mean wet slushy carpet. With the stone floor you don't have the worry of any water damage.
Did I mention it also looks great
IMO the only time things don't look uniform is when you have mismatched hardwoods.
creeper is offline   Reply With Quote
Old 09-15-2012, 01:06 AM   #3
Rewards Points: 264
I think both options could work well. However, with hardwood in an entry you would want to be sure to clean up water right away. If you don;t want to deal with that then go with the tiled entry.
Awoodfloorguy is offline   Reply With Quote
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 4 06-07-2017 06:24 PM
How to cut exhisting flooring in the doorway jjpar Flooring 8 10-26-2011 11:01 AM
Replacing torn up Linoleum flooring rippedupfloor Flooring 0 06-09-2010 02:38 PM
Basement flooring options.. Tommy2 Flooring 9 02-14-2009 07:06 PM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 11:32 AM
