Old 09-22-2009, 06:16 PM   #1
Default Replacing Floor - HELP
Hello,
My wife and I have a cabin in the north woods of Wisconsin. It’s old. We are slowly renovating the whole thing.
It has a subfloor with some type of particle board underlayment over the top of it throughout. The subfloor is fine. We sprayed in closed cell foam insulation in the crawl space between floor joists so I don’t want to touch the subfloor but the underlayment is dried and cracked and bowed in some places and I would like to replace some or all of it before we put down hardwood floors and carpeting. My question is how do you remove the underlayment if the bottom plates for the walls were built on top of it? Do I just cut as close to the walls as I can and then just butt up the new underlayment to that? Are there special tools for this? Would a flush cut saw help me? Also what about room transitions? For example the same piece of underlayment extends from the hallway into one of the bedrooms. The underlayment in the bedroom wasn’t bad so that floor has already been carpeted but the underlayment in the hallway isn’t so good so I need to cut it out and replace it. It will receive hardwood in the future. How do you cut the underlayment across the door opening and make it flush up with the new?
Sorry if these questions are confusing. I am just trying to figure out how to replace the underlayment when the walls are built on top of it and when some rooms need replacing and some don’t.
Thanks in advance for any help you can provide.
Tom5151 is offline   Reply With Quote
Old 09-24-2009, 07:06 PM   #2
I suggest that you use a sawsall ,put the blade in up side down.
Do a shallow skim cut deep enough to cut into the underlayment.
What you can't cut with the sawsall,you'll be able to get with a chisel.
Old 09-25-2009, 11:18 AM   #3
Ah...well thats a creative idea. I was going to use the circular saw and get to within about 1.5 inches or so of the bottom plate but your approach may get me right there...thank you.
More On This Topic
If you're looking for carpeting you can install yourself consider carpet made in tiles of varying sizes. The major benefit of carpet tiles is the ability to replace only 1 or 2 tiles if staining occurs, while leaving the rest of the carpet intact. Follow... Read More »
Hi I am Betty Ingham, and I am speaking on behalf of Expert Village. The floor in this house have all been replaced because the floors were originally so beaten up and so patched that we really couldn't use them. So, we got the wood from a mill, and it... Read More »
Hi! I’m Tad Donley and I’m speaking in behalf of Expert Village. I’m giving you tips on how to make your own recording studio. Hardwood floors, let me tell you about that, I would be wary of hardwood floors, it is the mirror effect that... Read More »
With so many styles of flooring available for your bathroom, how do you decide? Is tile your style, or is vinyl a better choice? If you are overwhelmed with the many types of bathroom flooring, here are a few tips for deciding which type is right for you... Read More »
Isolation in your recording studio needs to be at the front of your mind. Improper isolation will result in rumble, bleed and unwanted resonance in your recordings. One of the places you need to consider isolation is in your floor. Rumble and vibrations... Read More »
Replacing aluminum windows installed in 1992 cocean Carpentry 12 09-01-2009 12:24 PM
Replacing sliding patio door problems marlinpuppy Building & Construction 2 02-22-2009 10:11 PM
HOWTO: Determine if a wood floor needs replacing johnathanamber Flooring 0 01-14-2009 11:51 PM
Replacing windows in a Bedford Stone home tim_the_toolman Building & Construction 6 12-02-2008 09:27 AM
Replacing Asphalt w/ Cedar Shingle pbehnke Roofing 1 05-06-2008 03:28 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
