Old 09-17-2008, 03:49 PM   #1
Replacing Damage Planks in Laminate Floors
I am getting conflicting answer on how to replace a damaged plank in the middle of the laminate floor. One suggest to remove the planks starting from the last plank until you reach the damage plank is require. Another, told me that you can just cut the damage plank in a way so that you can pretty much lift it out and replace it with a good plank. Which is the best way? I also read instruction on how to make these cut to safely remove the damage plank. Does the technique require to replace the plank depends on whether its a glueless (click) or a glued plank or either technique would work?
manoa115 is offline   Reply With Quote
Old 09-18-2008, 06:56 AM   #2
I disassemble the floor up to the damaged board.
Personally I have never attempted a single plank replacement in a click together floor. The were difficult enough to do in a glue together and never really look right to me anyway
mike costello is offline   Reply With Quote
Water damage below laminate floor ediconu Flooring 10 01-23-2012 01:19 PM
Replacing laminate in the middle of the floor! greenlake Flooring 3 01-23-2008 01:16 PM
Putting laminate floors upstairs..what should I do with my stairs genyaf Flooring 4 01-02-2008 11:52 PM
Buckling of Laminate floors branjack Flooring 13 12-26-2007 01:38 PM
Sound Guard and laminate floors ck1 Flooring 5 01-15-2006 06:09 PM
