Replacing Carpt Stairs With New Hardwood - Flooring - DIY Chatroom Home Improvement Forum
Old 12-15-2011, 10:59 AM   #1
Replacing Carpt stairs with new Hardwood
Need some advice
Should I remove the plywood on the exsisting risers. they are 3/4 inch plywood. my measurment show that the show 7 3/4" from the top of one stair trad to the next one the tread width is 9" form the face of a riser to the face of the next riser. I assume that the risers are cut 7 3/4 " high by 9 3/4 deep. My new treads are 1" x 11 1/2 Red oak, and the risers are 3/4 red oak. seems to me that it would be eaiser to just use construction adehesive and 2 1/2 spiral finish nails which would give me a lot of surface to glue to. We have 17 of these stairs going to the second floor they provide the only access to the condo. my main concern is safety. And meeting code. Also there is no skirting just drywall on both sides, cheap and dirty construction with gaps between the dry wall and the stairs filled in with tape and mud.
Robert Vogt is offline   Reply With Quote
Old 12-15-2011, 11:29 AM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Originally Posted by Robert Vogt
Need some advice
I think code is already violated with your treads only being 9".
And I wouldn't remove the plywood.
Your new kit consists of "false treads and risers" as they are made to go over the "real" treads and risers.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
The Following User Says Thank You to titanoman For This Useful Post:
Robert Vogt (12-15-2011)
Old 12-29-2011, 11:37 AM   #3
Rover4's Avatar
I thought the tread retro kits ("false treads and risers") were 5/8" thick. He said his new oak treads were 1" thick. Isn't that a full tread? How thick is a "real" stair tread?
Rover4 is offline   Reply With Quote
Old 12-29-2011, 11:43 AM   #4
Disabled wood vet
titanoman's Avatar
Uh...Yes. Those must be the whole treads then. To be honest I haven't worked with those before.
Old 12-29-2011, 11:46 AM   #5
Disabled wood vet
titanoman's Avatar
Oops.
Old 12-29-2011, 01:15 PM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 504
Regular treads are 1" thick, what do you have for treads now? If they are thicker or thinner than what you plan to reinstall you may not be in code. Also if you plan to install 11 1/2" treads on a 9 3/4 inch cut you will need to rip 1/2 inch off the back of your treads, that is too much over hang of the nosing to be in code. Don't rip all of the treads as the top step may be a little different according to how the stairs are framed.
If the 3/4" plywood you have for risers now looks good enough to you, there is no reason to replace it. As for the gaps in your sheet rock why not install skirt boards, here is a link that will show you the easiest way to do that.
Stairway skirt board template - easy
I am not aware that they make spiral trim nails but it has been a while since I was in business, I used 10d or 12d finish nails. Be sure to glue everywhere wood touches wood.
Oh, and nail the riser to the back of the tread after applying glue. Don't gob on the glue as it will ooze out and will mess up your treads, glue spots don't take stain well.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 12-29-2011, 02:01 PM   #7
Experienced
Jackofall1's Avatar
Heres a thought, if you don't remove the plywood and mount the treads on the plywood, the first step will be +1" (tread thickness) and the top step will be -1" to the landing, now that would definately be a code violation.
Mark
Lay New Hardwood On Hold Hardwood TJfive0 Flooring 3 04-30-2011 05:50 PM
replacing carpet with wood on stairs deboril Carpentry 1 10-06-2010 07:57 PM
Hardwood Stairs warnerww Flooring 9 04-24-2010 07:56 AM
Redoing stairs with nosing and hardwood dfloors Flooring 1 03-12-2008 10:38 PM
Hardwood on stairs? basledder Flooring 4 03-07-2008 05:06 PM
