Replacing Carpet With Vinyl - Flooring - DIY Chatroom Home Improvement Forum
Old 01-07-2012, 07:58 AM   #1
Rewards Points: 31
Replacing carpet with vinyl
Our mud room currently has carpet and we are looking to replace it with vinyl self stick tiles.
I am tackling this myself and have put the self stick tiles over vinyl sheeting but had a nice clean surface to work with.
The carpet that is in there is the pad attached carpet (one piece). What is the best way to get this up and clean the sub-floor before I lay the vinyl?
I am using the self stick vinyl but would like a little added security, is there a certain adhesive product that can be purchased at Menards, Home depot, or Lowes that I can use with the self stick tiles?
Thanks in advance.
Willis
shoothebunnies is offline   Reply With Quote
Old 01-07-2012, 09:21 AM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 82
If the old carpet was glued, you will have to hand scrape the whole floor. You can use the back side of a trowel and put a very light coating of tile adhesive down before you install the tile. It needs to be pressure sensitive adhesive and needs to dry clear before any tile is installed.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Staining after vinyl and carpet removal Duration Flooring 0 08-03-2011 02:41 PM
getting rid of carpet > concrete floor > polish or stain? johnlvs2run Flooring 24 11-23-2010 10:31 PM
replacing carpet with wood on stairs deboril Carpentry 1 10-06-2010 07:57 PM
Grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr chetsy Off Topic 9 12-03-2008 06:41 AM
