Old 05-05-2012, 08:32 PM   #1
tam needs help's Avatar
Replacing carpet with linoleum
I am wanting to redo my bathrooms and one of them has carpet. I have some linoleum that my son is going to give me that's leftover from a bathroom in a house he just got, but I don't know how to install or put it in. It's not big enough for anything in the house he is in but I am pretty sure I can do both of my bathrooms with it any help or suggestions would be appreciated!!
tam needs help is offline   Reply With Quote
Old 05-05-2012, 08:55 PM   #2
Carpet in any bathroom is never a good thing.
Remove it the padding and the carpet strips and see just how much subfloor rot you have.
The toilet, 1/4 round and anything else sitting on the floor has to be removed.
Your going to have to find out what's under the carpet.
There's going to have to a layer of 1/4 sublfoor rated underlayment that gets attached every 4" on the outsides and every 6 to 8" in the field, with floor leveler to fill the seams and any flaws.
The flooring gets precut over sized, and rolled up. Your going to have to have a tooth trowled to spread out the adhesive. Glue gets applyed at one end of the room where your going to start rolling it out leaving a space on the edges so as the glue gets pressed out it does not make a mess on the walls. Once layed you go over the whole floor with a floor roller.
It would be a really simple and not that expencive job for someone who does floors all the time. SO you may want to concider getting it done for you.
Old 05-06-2012, 07:09 AM   #3
Ok thank you for the advice I'll check into having it done appreciate it!!
Replacing torn up Linoleum flooring rippedupfloor Flooring 0 06-09-2010 03:38 PM
bubble under carpet after water spill - fixing psittacus Flooring 4 03-06-2009 02:23 AM
Finishing Basement, carpet install order? tigerbalm2424 Flooring 33 07-24-2008 09:35 AM
Material to use for replacing linoleum (glued down). spookercat Flooring 2 06-26-2008 12:51 AM
Carpet Glued On OLD linoleum-HELP gradlass Flooring 5 09-30-2007 09:26 PM
