Replacing Carpet With Bellawood In Multilevel Condo - Flooring - DIY Chatroom Home Improvement Forum
Old 02-02-2010, 06:31 AM   #1
replacing carpet with bellawood in multilevel condo
[IMG]/Users/dianestefanick/Pictures/iPhoto Library/Modified/2010/Roll 215/CRW_5490_2.jpg[/IMG]I want to replace carpeting with bellawood in a multilevel detached condo.
The top of the stringer is flush with the subfloor.
How do I put the nosing on with 1"+ stringer in both sides?
diankay is offline   Reply With Quote
Old 02-02-2010, 10:52 AM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 182
Bella wood from Lumber Liquidators? That is not a very good product.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 02-02-2010, 11:43 AM   #3
Your opinion on my choice of product was not solicited. Hopefully someone can give me direction on my question.
Old 02-02-2010, 08:00 PM   #4
msv
Hardwood pro
msv's Avatar
that kind of attitude is not going to benefit your purpose... it just so happens, the people you are expecting advice from "kinda" know their s..t.... we do this for a living... he was just expressing an oppinion on the subject...
and to think i was SO ready to type the answer to your problem before i saw you second post.....
50% down, 50% after all your complaints....
Hardwood Floor Refinishing Roswell
msv is offline   Reply With Quote
Old 02-03-2010, 06:14 AM   #5
For my first post and looking for an answer, to be honest I was surprised that was all he had to say without any suggestions or direction. So yes, I responded defensively excuse me. I most certainly can take constructive criticism but right out of the gate like that was NOT what I was expecting. Money is an object and I thought that was a good choice. As a SWF do it yourselfer all I wanted was help. This is not the welcome and lack of encouragement I expected!
Old 02-03-2010, 07:24 AM   #6
you can make bella wood work. you question is kinda hard to answer. as an installer.i would miter all my edges and glue and brad nail them together. you will need to get rid of the over hang on the steps.there may be an easier way, thats just how i would do it.good luck. the first reply was trying to be helpful hoping to make sure you know what you buying.
just tile is offline   Reply With Quote
Old 02-03-2010, 11:05 AM   #7
msv
Hardwood pro
msv's Avatar
ok, i've tried to picture it the best i could.... the stair nosing has a lip that "grips" onto the raiser... you need to trim that near the wall, so it can fit the stringer... i imagine you're gonna paint the stringer, right?
just trim the lower part of the overhang.. if your cut is not going to be perfect, you can use caulking... make sure you use both glue and nails to install the nosing...
Old 02-03-2010, 11:10 AM   #8
msv
Hardwood pro
msv's Avatar
I don't get it... what edges are you gonna miter?
I agree with the part about the subflooring needing to be cut flush with the raiser... it's a must!
What are you gonna do about the steps/raisers? keep carpet? go with wood? if wood, what kind?
Old 02-03-2010, 02:29 PM   #9
sorry i cofused myself which isn't hard to do most of the time. i was refering to the side; where that 1\2 inch lip is. if your going to put wood there. if not what are trimming it with?
Old 02-03-2010, 05:22 PM   #10
Rewards Points: 182
This is why I posted what I did. I was hoping you hadn't already bought it.
http://www.complaintsboard.com/compl...rs-c26238.html
Carpet cleaning - sump water n0c7 Flooring 17 08-29-2011 07:04 AM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
Good equipment to use for carpet cleaning? Beth777 General DIY Discussions 5 08-29-2008 08:16 PM
Finishing Basement, carpet install order? tigerbalm2424 Flooring 33 07-24-2008 08:35 AM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 07:48 PM
