Hi Bob,
OK, you have 2x8 joists @ 16" o.c., what is the unsupported span? I recommend that you start by sistering those joists since the floor is open. But you should anyway because of the added weight the tub and in case you decide to install natural stone tiles. You also need to add additional joists or blocking to support ends of plywood that were cut, and so do not have t&g.
Your base subfloor should be 3/4" subfloor grade exposure 1. If you go with stone tiles and the joists are stiff enough, you will add a second sheet of plywood, I recommend at least 3/8", prefer 1/2" or thicker. You then install either a tile backer board or a membrane like Ditra. Then the easy part, the tiles. You may not need the second sheet of plywood if you stick with ceramic or porcelain tiles, but it would give you a better floor. The more plywood the better.
Measure and post back with the unsupported span and see if you can read the species and grade stamped on some of the joists.
Jaz
Tile 4 You Inc. Troy, MI
KERDI Shower Expert...DITRA Installs...Containers of TRAVERTINE Direct from Turkey Quarry...SAVE 40-70%
