Replacing 3/4 Inch Sub Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 11-22-2012, 08:59 AM   #1
replacing 3/4 inch sub floor
What would it cost to replace 900 square feet 3/4 inch sub floor.
egabbac is offline   Reply With Quote
Old 11-22-2012, 09:07 AM   #2
chitownken's Avatar
Rewards Points: 510
Materials only? Or labor as well? And what do you want to replace it with? Plywood, OSB, 1X boards?
chitownken is offline   Reply With Quote
Old 11-22-2012, 09:16 AM   #3
DIY staff
Rewards Points: 7,174
Why are you changing it? Call your local lumber yard and get the cost of the subflooring you want and add the cost of fasteners and adhesive---add in a compressor and gun if you don't have one already---
Hammer,pry bar --saw and blades---and you have the cost---
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
How to repair a concrete floor we just had repaired! timbo59 Flooring 11 01-04-2012 06:15 PM
Replacing a wood laminate floor tarmagon Flooring 5 10-22-2011 07:19 PM
Replacing tile in bathroom floor (2x2 tile) Paul8434 Remodeling 1 09-05-2011 06:06 PM
Need 2 inch floor padola07 Flooring 2 08-15-2008 05:54 PM
