Replacement Of Laminate Floor In Kitchen - Flooring - DIY Chatroom Home Improvement Forum
Old 03-05-2015, 02:26 PM   #1
Rewards Points: 2
Replacement of Laminate Floor In Kitchen
I have a laminate floor in my kitchen that is starting to fail, due in large part to bad installation. The click seams are breaking and the panels now flex at the seams when walked on.
My question: Is it possible to replace this laminate floor even though it extends under the kitchen cabinetry without having to remove the cabinets first? The kitchen cabinets were installed over top of the floor.
Rob
MaxArk68 is offline   Reply With Quote
Old 03-05-2015, 05:17 PM   #2
Rewards Points: 13,274
#1, Laminate is a very poor choice in the first place for any kitchen, bathroom, laundry room.
One wet event and it's trash.
#2, Never ever should have been installed under the cabinets.
Best bet is to cut it out with a Toe Kick saw and a sawsall with a short course toothed blade and replace it with some other type of flooring.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
JazMan (03-07-2015), rusty baker (03-05-2015)
Old 03-06-2015, 10:16 PM   #3
funflyer's Avatar
Rewards Points: 428
Like joe says, use a toe kick saw. Laminate can and has been used in kitchens successfully. You need to glue the joints to make them waterproof but this makes for another problem when a piece needs to be replaced. A flexible, waterproof glue like eurobond is good.
funflyer is offline   Reply With Quote
Old 03-07-2015, 11:46 AM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 42
I have seen a dog's water dish ruin "sealed" laminate.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
joecaption (03-07-2015)
Old 03-07-2015, 01:39 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 290
Dog's dish should be on a mat and preferably not on wood floors. I've seen high-end engineered oak ruined within a few years. Solid " would do the same eventually.
If a floor might get wet and might not be attended to immediately, use vinyl or ceramic instead.
Jaz
Old 03-07-2015, 08:38 PM   #6
funflyer's Avatar
Rewards Points: 428
Seald how? Obviously not properly. I have seen properly sealed (glued) kitchen laminate last for over 20 years.
Old 03-09-2015, 06:44 PM   #7
Rewards Points: 42
Whatever you think. Most pro installers won't put it in a wet area.
Old 03-12-2015, 03:18 AM   #8
Rewards Points: 104
It might be easier, but it wouldn't be better. A laminate floor has to be free to expand and contract with seasonal changes in humidity, and it can't do that with heavy cabinets resting on top of it. you run the risk of scratching your new floor if you install the cabinets after it's in place. Those are all good reasons to lay a kitchen floor after the cabinets are in.
marks.fletchers is offline   Reply With Quote
Proper replacement of saddle valve on kitchen lines littlehoov87 Plumbing 5 07-12-2012 11:25 AM
Kitchen island with laminate end panels morpho Carpentry 8 06-07-2012 07:41 PM
Wood Laminate in the Kitchen quesenbarrett Flooring 4 03-21-2011 02:58 PM
Replacement of flush mounted cutting board in kitchen counter top Humby Kitchen & Bath Remodeling 1 07-31-2010 03:45 PM
laminate floor in Kitchen yellow.shoes General DIY Discussions 6 02-28-2009 12:36 PM
