Old 05-20-2011, 01:39 AM   #1
Smile
replace wall tile without damaging floor tile
Hello,
I would like to replace the tile on the surround of my bathtub. The floor tile however was not set under the surround wall tile. Is it possible to replace the surround tile without damaging or replacing the floor tile around it?
Thanks,
bruswain is offline   Reply With Quote
Old 05-20-2011, 06:54 AM   #2
Super Moderator
Post a picture---Are you saying that the floor was installed after the wall was done and the wall tiles are trapped behind the floor tile????
Old 05-21-2011, 01:00 AM   #3
sorry, I am traveling at the moment so cannot take a picture, but you are correct, it is trapped behind the floor tile.
Old 05-21-2011, 07:29 AM   #4
Super Moderator
You should be able to wiggle out the wall tiles that are trapped----If your new tile is thicker than the old--you will easily hide the gaps.--Mike--
Tags
floor, replace, tile, wall
Drain tile questions for retaining wall installation. Tmaxx1 Landscaping & Lawn Care 11 06-10-2011 12:17 PM
Does this plumbing repair mean I have to replace the tile wall? darsunt Plumbing 2 12-02-2010 08:51 PM
Retaining Wall Weeping Tile Problem cg3459 Landscaping & Lawn Care 3 06-16-2010 07:22 PM
Grout or Caulk where floor tile meets wall tile? britt_schaeffer Tiling, ceramics, marble 3 11-02-2009 03:42 PM
Temporary Tile Wall auntd Building & Construction 1 05-10-2008 11:42 PM
