Replace Or Seal Particle Board Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 02-16-2013, 05:52 PM   #1
Replace or Seal particle board floor
I'm wanting to find out when to replace rather than seal a particle board floor. And how good sealing a floor is against the release of gases like formaldehyde.
Some of the floor has had water damage due to a leak in the roof. It is water stained, but doesn't appear (from the top) to have expanded or become flakey.
In an ideal world I would replace all the floors to remove the old 70's particle board, cost and time is however an issue.
Superwho221 is offline   Reply With Quote
Old 02-16-2013, 06:05 PM   #2
Rewards Points: 13,444
Partical board is useless as a subfloor, if it was my job I'd get rid of it.
Old 02-16-2013, 06:43 PM   #3
Rewards Points: 264
I agree with Joe. Get rid of the particle board. Plywood isn't that expensive.
Awoodfloorguy is offline   Reply With Quote
Old 02-16-2013, 06:55 PM   #4
Thanks for your feedback guys. It's a little more for me to replace the subfloor as I no longer live in the USA, you guys can get plywood for around USD30 a sheet, I'm paying nearly 4 times that much per sheet. Which is why I'm even bothering to consider if I can just seal the floor.
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Particle Board Floor saw04 Flooring 7 11-14-2011 04:17 PM
Tile over Particle Board dgun357 Tiling, ceramics, marble 2 01-16-2010 08:00 PM
Particle board underlayment help diynut Flooring 5 03-07-2006 05:22 AM
particle board / hardibacker fish3211 Flooring 4 08-10-2005 08:32 PM
