i have carpet in my living room i want to put wood flooring in but i have no insulation under the carpet there is ply wood there and nothing under that but ground i dont like carpet want should i do please help
Add a layer of 1/4" cork. The R-value of cork depends on the dinsity. Typically cork has an R-value of 3.1 per inch. This is not high but, it can feel like a lot on a concrete floor. There are many places to buy cork. It comes 4 ft. wide and is most often sold in 100 ft. lengths. Prices vary from .75ft. to 2.00ft. Check the density first.
If you like hardwood you may be O.K.----You may want to insulate the floor from below installing the insulation with the vapor barrier UP--facing the plywood.
Where are you located? Does it get cold in the winter?
i live in staatsburg n.y. it gets very cold and in that room alot it feels like there is no insulation in there thanks for all ur help
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
