-   -   replace carpet with wood flooring (http://www.diychatroom.com/f5/replace-carpet-wood-flooring-112511/)
teresafandel 07-31-2011 10:10 AM
i have carpet in my living room i want to put wood flooring in but i have no insulation under the carpet there is ply wood there and nothing under that but ground i dont like carpet want should i do please help
woodman58 07-31-2011 02:23 PM
Add a layer of 1/4" cork. The R-value of cork depends on the dinsity. Typically cork has an R-value of 3.1 per inch. This is not high but, it can feel like a lot on a concrete floor. There are many places to buy cork. It comes 4 ft. wide and is most often sold in 100 ft. lengths. Prices vary from .75ft. to 2.00ft. Check the density first.
teresafandel 08-01-2011 06:23 AM
i not have concrete floors its just plywood will it still work
oh'mike 08-01-2011 07:25 AM
Is the floor insulated from the bottom?
Hardwood floor could be installed if the floor is not damp from the earth in the crawl space.
teresafandel 08-02-2011 03:10 PM
no from top its 2 by 10s and then plywood and there is a crawl space would tile b better
oh'mike 08-02-2011 05:59 PM
If you like hardwood you may be O.K.----You may want to insulate the floor from below installing the insulation with the vapor barrier UP--facing the plywood.
Where are you located? Does it get cold in the winter?
teresafandel 08-03-2011 06:10 AM
i live in staatsburg n.y. it gets very cold and in that room alot it feels like there is no insulation in there thanks for all ur help
