Replace Carpet And Vinyl With Laminate - Flooring - DIY Chatroom Home Improvement Forum
Old 02-03-2012, 03:51 AM   #1
Replace carpet and vinyl with laminate
Hi all, I'm currently in prepping phase of my laminate install on the 1st floor of my house w/basement(built 2002). Carpet(living room) is removed and I planned to install laminate over the the vinyl(hallways). However, the subfloor under the carpet is now 1/4 inch lower than the vinyl. I was thinking of glueing and nailing down 1/4 inch OSB to make both areas level. A few questions, I have.
1) Is OSB okay to use or should I go with plywood at almost 3 times the cost?
2) Do I need to let the OSB or plywood acclimate like the laminate requires?
3) Do I need to allow for an expansion gap when installing OSB or plywood? 1/2 or 1/4 inch gap?
4) After the OSB or plywood is installed, can I immediately start laying laminate, or does that need to set for a day or two?
Appreciate the help and knowledge. Thanks!
jlobb2 is offline   Reply With Quote
Old 02-03-2012, 04:45 PM   #2
best to just staple it with 1" staples with 1/4" crown
1) Is OSB okay to use or should I go with plywood at almost 3 times the cost? osb is fine
2) Do I need to let the OSB or plywood acclimate like the laminate requires? No
3) Do I need to allow for an expansion gap when installing OSB or plywood? 1/2 or 1/4 inch gap? No
4) After the OSB or plywood is installed, can I immediately start laying laminate, or does that need to set for a day or two? Yes
HarryJ is offline   Reply With Quote
The Following User Says Thank You to HarryJ For This Useful Post:
jlobb2 (02-04-2012)
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Replacing carpet with vinyl shoothebunnies Flooring 1 01-07-2012 09:21 AM
Laminate or carpet pinkcamaro17 Flooring 2 07-09-2011 11:15 AM
laminate over uneven vinyl Fox75 Flooring 2 04-19-2011 12:40 AM
Carpet vs Laminate and Vinyl vs Ceramic Kaminberry Flooring 5 02-26-2007 07:03 PM
