Repairing A Rotted Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 07-29-2012, 07:05 PM   #1
Repairing a rotted floor
Hi,
I am new here and I am taking on a tiling project in my bathroom. I tore up the existing tile and found a rotted floor underneath the toilet. This stuff was just crumbling apart so I decided to take the subfloor out. Due to pipes and a wall, the closest joist to the wall is far out of reach for me to get to. My question is how would I go about increasing the "structural integrity" of the new subfloor if I cannot attach it to the joist that is sitting under the wall? I was thinking that I could place some cross beams, but would that make the new floor stable and safe enough for the new tile and toilet? Thank you in advance for any advice!
Thanks,
Adam
adam.r is offline   Reply With Quote
Old 07-29-2012, 08:13 PM   #2
DIY staff
Rewards Points: 7,174
Add 2x4 blocking on the three sides not supported by the joist--screw to the decking and the floor joist
adam.r (07-29-2012)
Old 07-30-2012, 09:43 AM   #3
Rewards Points: 13,732
If you use a Toe Kick saw you can cut that floor out right along the bottom plates.
I'd use 3/4" Advantec T&G as a subfloor not plywood, with constrution on the tops of the floor joist for added streingth.
Advantec is more moisture resistant then plywood.
Replacing Rotted Top Plate in Bottom Floor Garage JBGriffith General DIY Discussions 14 04-27-2012 01:49 PM
How to repair a concrete floor we just had repaired! timbo59 Flooring 11 01-04-2012 06:15 PM
Repairing rotted 4x4 deck posts j.e.b. Building & Construction 3 03-13-2011 07:33 AM
Cupping red oak floor rocks911 Flooring 9 02-10-2011 12:42 AM
Repairing rotted studs against exterior wall sleepyscout Carpentry 11 07-01-2009 01:31 PM
