Repairing A Popping Engineered Hardwood Installation - Flooring - DIY Chatroom Home Improvement Forum
Old 04-20-2012, 06:34 AM   #1
Repairing a popping engineered hardwood installation
I've found UTube videos which show the perfect way to solve this problem injecting glue under the planks using a water based wood glue.
There are also kits in the market which are expensive and use special formulated glue.
What type of glue would you recommend for this repair, regular wood glue like Elmer;'s or specialty glues?
ameneses54 is offline   Reply With Quote
Old 04-20-2012, 10:39 AM   #2
Rewards Points: 13,458
I see no way you would ever get the glue injected where it needs to go.
hardwood on engineered floor? kalpi Flooring 1 09-27-2011 06:32 PM
Engineered Hardwood: Inlaid transition? SteveSmith98 Flooring 6 03-24-2009 11:21 AM
hardwood flloring installation bannasch Flooring 1 07-19-2008 12:44 AM
Hardwood floor installation on 2nd floor - underlayment necessary? digexpressions Flooring 2 11-30-2007 10:15 AM
engineered hardwood installation; Floating or Glue? El Buey Flooring 4 08-17-2007 02:53 PM
