Repairing/fixing Marmoleum Tiles - Flooring - DIY Chatroom Home Improvement Forum
Old 11-21-2009, 07:25 AM   #1
Question
Repairing/fixing Marmoleum tiles
Hello--
I recently installed click-on sky-blue marmoleum in our kitchen. It came out fairly well -- I was especially careful to put in luan subflooring and make it very level.
However, there are 2 problems that occurred. First, one of the 3x1 tiles didn't exactly fit (click-on) as well as I wanted, and there is a noticable line/separation around 2 edges of that 3 x 1 tile (one 3' edge and one 1' edge).
I read somewhere that the way to "fix" that or cover it up was to put clue around the two edges and sand the top of a spare piece of marmoleum over the clue. That process certainly helped, but if one looks one can still see a color /finish difference. Is there any way finish that will blend the sky blue (marblish) finish and the edges / separations?
2nd problem is one that I didn't realize until after I had installed the entire kitchen. Marmoleum click on requires about 30 degrees elevation for the click on to work. I had some cabinets that "overhang"the floor and allow only about 15 degrees of elevation. I should have removed the cabinets, but that was a really big job (I think), and so I just tried to cut the marmoleum and not use the click on part around the cabinets. That process also produces these edges that one can see. Again, I tried the trick of glue and sanding an unused piece of same marmoleum. Again, that helps, but one can see a color or light reflection difference.
If you look at the sky-blue marmoleum finish, it has a marble like top consistency of color, but underneath, it is a different non-marble like consistency. So, I can see why the glue and sanding doesn't really work. How do I make the same kind of marble like consistency to the color?
Anyway, any advice would be really greatly appreciated.
diynickstam
NickStam is offline   Reply With Quote
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
6"x6" porcelain tiles?????? Quickdraw Flooring 15 12-04-2009 07:29 AM
How to/what to use to cover potentially asbestos tiles? TomServo Flooring 7 09-10-2009 12:59 PM
calking backer board to tub glassman General DIY Discussions 13 06-19-2008 09:41 PM
Shower Tiles Easily Pop Out - Bad Installation? kabowma0 Remodeling 6 04-23-2007 08:43 PM
