Repairing Cracked Slab & Moisture?? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-18-2012, 01:57 PM   #1
Repairing cracked slab & moisture??
I recently had my foundation repaired requiring interior piers. My foundation has several cracks running thru it and I have noticed moisture build up around the cracks and edges of the new cement where the piers were placed. What is the best way to repair this so I can put down new carpet and laminate flooring without risk of mold forming? Need Help!
momsays is offline   Reply With Quote
Old 05-18-2012, 10:28 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 290
Hi Mom,
There isn't anything necessarily you can do right there where the water is. You need to figure out where the water is coming from and fix that. You can't just fill a crack and be done. The water will still be there, and water always wins.
Jaz
Fix or Replace Porch Concrete Slab Majoram Building & Construction 10 06-25-2011 03:45 PM
moisture under slab, roughed-in plumbing bergerdude Building & Construction 4 03-25-2011 09:29 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
engineer wood floor @ uneven Slab on grade gtimk4 Flooring 0 03-21-2010 07:29 PM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 11:29 AM
