Repairing A Broken Settled Cement Slap To Repair Broken Tiles - Flooring - DIY Chatroom Home Improvement Forum
Old 02-20-2012, 02:43 PM   #1
Repairing a broken settled cement slap to repair broken tiles
I purchased a home with an in-law appartment. I am told the inlaw unit was originally a 3 car garage. We removed some carpeting over a previously tiled floor. Near the edge of the slab footing, there is a breakage of tiles about 16 feet long in a straight line approximately 12 inches from the outside wall. It is very apparent the floor has settled. I can tap along the breaks and on one side you will hear a solid sound and the other side is a hollow sound, You can physically feel and observe the downward angle of the slab, causing the breakage. My question is: After I remove the broken tiles, how should I fill in the section that has settled and how do I smooth or sand down the higher sections. I am open for all suggestions.
Dtlsr42 is offline   Reply With Quote
Tile repair question--looks like the backing behind the tiles has some issues jbeall Building & Construction 11 06-19-2011 02:02 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Cement Porch and Step Repair tennyman Building & Construction 1 04-23-2010 02:31 PM
broken pipe under cement atichargr Plumbing 5 04-23-2009 12:15 PM
Repairing Shower Tiles, Gap between Tub/Drywayll Zulu Plumbing 7 01-22-2008 02:25 PM
