Repair Small Wear Marks In Stair Treads - Flooring - DIY Chatroom Home Improvement Forum
Old 11-04-2013, 12:08 PM   #1
bryanp22's Avatar
Rewards Points: 288
Repair small wear marks in stair treads
My basement stairs have some small wear marks from use as my house is 60 years old. A plaster wall was built on top of the treads when the house was built so removal will not be easy as the plaster wall rests on top of the stair right where the stringer is.
What could I use to fill in the slight wear marks? Would woo putty be durable enough? The other option I am considering is the oak overlays for the treads but that's quite more involved and pricey.
bryanp22 is offline   Reply With Quote
Old 11-04-2013, 02:16 PM   #2
Rewards Points: 12,804
Filler will not work unless it's covered with carpet, even then it may crumble.
Over lays need a solid surface under them, (no gaps).
Sand them or replace them. Plaster can be repaired.
Old 11-04-2013, 02:19 PM   #3
K&B Designer
Live_Oak's Avatar
You might want to embrace the authentic patina until you can deal with rebuilding the stairs.
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
Help reattaching refinished stair treads thekingofboggle Carpentry 4 09-20-2012 06:55 PM
replaced stair treads dhungy Flooring 5 06-20-2012 11:21 AM
New stair treads and flooring rickkeeter Flooring 2 02-24-2010 11:16 PM
Ugly old painted stair treads, with seriously raised grain. Salvageable? CharmCityFixer Flooring 9 01-29-2010 07:40 PM
Small engine repair tripower Tools 2 07-09-2009 04:28 AM
