Repair Bubbles In Wood Floor Finish - Flooring - DIY Chatroom Home Improvement Forum
Old 05-25-2011, 01:56 AM   #1
Repair bubbles in wood floor finish
The finish on my wood floors has popped up from my high heels, and I need to fix it!
I'm guessing that if I apply heat somehow to melt the finish bubbles, that could work but I don't want to make the issue worse.
Image attached of one of the many holes. Thanks for your help!
renter is offline   Reply With Quote
Old 05-25-2011, 06:29 AM   #2
DIY staff
Rewards Points: 7,174
What kind of wood is that--It looks like Luan to me---
Heating the finish will not help--the finish will not melt--it has actually come loose from the wood.
That's why I asked for the type of wood. I find some woods will not hold a finish --a small trauma can pop the finish loose because it's not bonded to the surface of the wood.---Mike---
Old 05-25-2011, 08:13 AM   #3
NACE Coating Inspector
mustangmike3789's Avatar
did you do a moisture check om the wood before applying the coating..
mustangmike3789 is offline   Reply With Quote
Old 05-25-2011, 11:39 AM   #4
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
I'm guessing from the OP's name she didn't install this and just wants a quick fix.
Old 05-25-2011, 06:51 PM   #5
DIY staff
This sounds like a tenant who caused damage to a cheap low quality floor--while doing something any high quality floor could take.
Shame on the landlord!
Old 05-28-2011, 03:23 PM   #6
Smile
The floors are made of Brazillian Cherry.
The condo is gorgeous with granite countertops, floor to ceiling stone bathrooms, and grown molding in the kitchen, living room, and bedrooms.
My landlord is a really great guy, but the floors may not be the best quality. I'd like to be able to fix this on my own if possible, as I probably shouldn't have been wearing heels inside anyway.
Any ideas? Thanks so much!
Old 05-28-2011, 03:24 PM   #7
Hi there! they are Brazillian cherry floors
Old 05-28-2011, 03:24 PM   #8
No I'm renting it
Tags
finish , finishing , wood floor , wood flooring
Help Need Wood identification :D x3 iloveusk8rboi Carpentry 3 10-15-2010 10:05 PM
click lock wood flooring and tile guessingo Flooring 3 09-15-2010 11:56 PM
How to repair vertical wood siding? darsunt Building & Construction 1 11-19-2009 07:46 PM
What To Prime Wood With to Accept Joint Compound? Lovegasoline Building & Construction 19 11-03-2009 06:04 AM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
