Renovating: 2 Layers Of Plywood Necessary For ? - Flooring - DIY Chatroom Home Improvement Forum
Old 06-19-2006, 07:59 AM   #1
Rewards Points: 150
Renovating: 2 layers of Plywood Necessary for PICS NOW
House: 1987 construction ranch with full basement
Floor: Previous DIY'er Tile over durarock over 2 layers plywood
Question: Is 1 layer of plywood i.e. the original subfloor strong/good/firm enough to tile over given I'll be using a layer of durarock.
Situation: Once I demo'ed the tile and durarock board and removed the center island, I descovered to my dismay that someone had doubled up on plywood. The original subfloor is visable at the edges of the kitchen, and it became obvious where original cabinets had been, they were set on only 1 layer of plywood. I'll be tiling approx. 700 sq ft. Kitchen entry way and hallway to 3 bedrooms. If I must keep the 2 nd layer, i'll have to install a 2nd layer throughout the house to get it level. If I can loose it, I pray to the renovation gods that they didn't glue it down.
I'd appreciate anyones opinons or direction.
Center island now gone, you can see the two layers, the one layer was put in with the center island in place...
Closer
Edge of room, notice original sub-floor at edge
Thanks,
Nathan
harleysilo is offline   Reply With Quote
Old 06-20-2006, 04:04 PM   #2
Rewards Points: 150
Not a single suggestions?
Old 06-20-2006, 10:14 PM   #3
renovations
You should have at least 1" and preferably 1-1/4" of plywood under tile. This is assuming that the joists are sized correctly and spaced 16" o/c. Then you put the cbu down over unmodified thinset, then the tile on modified thinset. The second layer of ply and the cbu should be screwed to the plywood not the joists.
What type of finish floor do you have in the rest of the house? Transitions are common, after a day or two you don't notice them, even in the dark.
Bonus is offline   Reply With Quote
DIY Chair mat from plywood and carpet tiles jbwaechter Flooring 3 08-20-2009 06:29 AM
Plywood Wall Sheathing? sandyman720 Building & Construction 13 08-02-2007 08:02 PM
Exterior plywood, not secured well enough mt232 Building & Construction 4 07-03-2007 09:34 AM
Exterior plywood mt232 Building & Construction 1 06-25-2007 08:59 AM
Backer board vs. plywood for tile underlayment allpraisebob Flooring 4 01-07-2007 07:44 PM
