Removing Wood Flooring - Cutting Close To The Edge Of The Wall - Flooring - DIY Chatroom Home Improvement Forum
Old 07-11-2007, 03:16 PM   #1
Removing Wood Flooring - Cutting Close to the Edge of the Wall
Hello all,
just ran into the builder of my house (we bought our house 7 years old) and he told me that my oak flooring was laid over 1x4's rather than 3/4 ply.
i'm planning to replace the flooring with engineered wood floor which i'll float over the existing sub concrete floor...after a layer of foam or whatnot.
anyway...is there a circ. saw that can get close enough to the wall so that when i cut the existing wood flooring, i can just replace the floor moulding/shoe to hide the gap?
rgmetro is offline   Reply With Quote
Old 07-11-2007, 10:06 PM   #2
Floorwizard's Avatar
I think most installers get as close as possible, then chip away with a chisle.
Floorwizard is offline   Reply With Quote
Old 07-12-2007, 06:21 AM   #3
RippySkippy's Avatar
Take a standard circular saw, run the side closest to the blade against the base and cut along all the base. It wouldn't take much with a decent pry bar to pop the chunks out. A jamb or toe kick saw would get very close to the base, not sure if it would get close enough to allow the shoe to hide the transition.
In my last house I popped the trim, layed the floor and re-installed the trim, and it didn't require a shoe. I wouldn't leave chunks of the old floor there...but that's just me.
RippySkippy is offline   Reply With Quote
Wood Flooring etc emptee A Flooring 1 08-15-2007 10:57 PM
Wood flooring in basement DIY4EVER Flooring 9 07-20-2007 01:04 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
wood laminate flooring in kitchen kjacobson Flooring 11 02-17-2007 02:20 PM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 09:14 AM
