Removing Vinyl Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 12-10-2009, 12:19 PM   #1
removing vinyl tile (help)
whats the easiest way to removing vinyl tile that hat has been glued down to a plywood floor. my hands are killing me from trying to scrape it off with a 2" blade
ghopper57 is offline   Reply With Quote
Old 12-10-2009, 04:39 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 182
If it's not old asbestos tile, use a heat gun or hair dryer. You can pick up a cheap heat gun for $20-25. What are you putting down next?
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 12-10-2009, 04:53 PM   #3
thanks,its not asbestos. ceramic tile, anything else i should know before installation. i hope i don't have to get this glue up. its a little tacky after i get the tiles up, but it seems to be drying out after the air hits it for a few hours. and its not thick its a light coat of glue
Old 12-10-2009, 05:00 PM   #4
Rewards Points: 182
I haven't done ceramic for years. I'll let one of the ceramic guys chime in.
Old 12-10-2009, 05:05 PM   #5
ive put ceramic in 2 other rooms and it turned out great but didn't have the glue in the other rooms thanks again and my hand thanks you to
Transition from grouted vinyl tile to carpet MI-Roger Flooring 2 11-29-2009 12:55 PM
Should I use tile or vinyl Quadfam4 Tiling, ceramics, marble 3 04-30-2009 10:58 AM
Vinyl Tile bailey46 Flooring 6 03-01-2009 03:04 PM
Removing Vinyl Tile Adhesive from Linoleum The Raven Flooring 3 07-22-2008 08:38 PM
vinyl sheet or tile (or allure) over old vinyl? thomase Flooring 8 06-30-2008 05:15 PM
