Removing Tile Floor Where Cabinets Sit On Top - Flooring - DIY Chatroom Home Improvement Forum
Old 03-23-2012, 03:55 PM   #1
JS2
Removing tile floor where cabinets sit on top
I would like to remove a tiled kitchen floor. When my home was built, the floors were done before the cabinets were installed, which means the cabinets are on top of the tiles. What is the best way to remove the tile flooring without having to remove and re-install the cabinets?
JS2 is offline   Reply With Quote
Old 03-23-2012, 08:37 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 422
Well, that's what happens when people take the easy route when installing the floor. When was your house built? What installation method, do you know? It might be possible to do depending on how it was installed.
Normally a good tile installation is good for 40-50 years at which time people get tired of the colors and change everything.
Of course the best way is to pull the base cabinets unless you have counter tops that are not being replaced and other issues.
Jaz
Old 03-23-2012, 08:58 PM   #3
Rewards Points: 14,306
Toe Kick saw with a diamond blade will do it.
Home Depot rents them or buy a cheap one at Northern Tool.
Old 03-24-2012, 02:29 AM   #4
DIY staff
Rewards Points: 7,174
Remove the toe kicks---then start the demolition--pop off the tiles under the cabinets far enough to clear the new toe kicks.
A toe kick saw could be used to remove the tile backer---what is under the tile now?
Cabinets over tile, or tile around cabinets??? harleysilo Remodeling 10 11-02-2012 01:25 PM
Travertine Tile Help MikeinTexas Flooring 1 09-07-2011 10:43 AM
removing tree roots from sewer tile 4just1don Plumbing 4 09-10-2010 07:23 PM
Replace kitchen tile without moving cabinets and countertop stubits Tiling, ceramics, marble 7 02-18-2010 10:56 AM
Tile Under New Cabinets? monkeystomach Flooring 3 02-15-2010 09:01 PM
