Removing Tile; Electric Tile Stripper Or Rotary Hammer? - Flooring - DIY Chatroom Home Improvement Forum
Old 07-21-2011, 06:22 PM   #1
Removing tile; electric tile stripper or rotary hammer?
Hello all,
I'm removing the 33 year old ceramic kitchen floor tile from a concrete base. It's a small kitchen and I'm going to re-tile it.
To remove the old tile should I use an electric tile stripper or a rotary hammer with a chisel blade on it? The local home supply store will rent me either tool.
Also in another room I'm removing vinyl tile from a concrete base in perpetration to smoothing the floor and installing glue down engineered hardwood.
Could I use the same rental tool for both (with different blades)?
The size of the ceramic kitchen tile to removed is 50 sf and the size of the vinyl tile to removed is about 120 square feet?
Which tool would be easier to use and which tool would do a better job removing the mastic/glue?
Many thanks in advance for the help.
Mack
mackaz is offline   Reply With Quote
Removing vinyl tile (at least I think it's some sort of vinyl) natecase13 Flooring 1 07-13-2010 10:55 AM
Removing Plastic Backsplash Tile ws450r Drywall & Plaster 5 07-12-2010 01:37 PM
Removing Ceramic Tile csnolan General DIY Discussions 1 10-26-2007 10:37 PM
Removing Ceramic Tile Blaze25 Flooring 2 11-16-2006 08:52 PM
