Removing Thinset From Subfloor - Flooring - DIY Chatroom Home Improvement Forum
Old 02-16-2010, 10:27 PM   #1
Ed
ripped out the old ceramic tile and i am going to replace with solid hardwood. Any thoughts on the best way to remove the thinset off the subfloor? I tried a handheld scraper with no luck. I also tried a hammer and ice scraper with no luck.
edfromma is offline   Reply With Quote
Old 02-16-2010, 11:09 PM   #2
Military Mom of 4
Snav's Avatar
Leveler - lots of it to fill cracks, dips, grooves and make it even.
However - I think it would be ideal to just take a skill saw - depth-set it to just cut out the top layer of subfloor and remove it all, put down new subfloor and start fresh.
You don't know what type of damage (water and otherwise) has been exactly on the subfloor - it might be weakened, rotted or molded.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Removing subfloor nickdu Flooring 3 07-28-2009 09:34 AM
Removing Subfloor for Wall Access Riven02 General DIY Discussions 7 04-17-2009 05:28 PM
Removing old thinset from subfloor gburg3 Flooring 3 12-15-2008 08:59 PM
Removing damaged bathroom subfloor icandoitmyself Flooring 3 10-23-2007 09:50 AM
Removing Subfloor, Leveling and install new.... dcd22 Building & Construction 5 07-13-2007 08:59 AM
