Removing Thinset - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-27-2013, 12:10 AM   #16
Rewards Points: 918
You can remove that glue stuff with the pvc floor in one swipe if you use a chisel and a hammer. Get a 1 1/4-1 1/2" wide chisel and hammer away at about a 60 degree angle. You can lower to a 45 degree angle if it scrapes off easily. But if you start to skim over it, then you need to raise the angle up a bit.
Is it slow and tedious? Yes.
Do you feel stupid stripping 1 1/4" wide path at a time? Sure.
Best to have at it in 30 minute increments, hopefully over two days. Stop and sweep or vacuum up frequently.
cleveman is offline   Reply With Quote
Old 04-27-2013, 03:16 PM   #17
Rewards Points: 280
Thanks for the input. But it ain't gonna happen! I will put down really nice sheet vinyl before I put that much effort into it If that does not work I will put in some indoor outdoor carpet.
But now I am confused. I have two people telling me that modern thinset will work over adhesive and some telling me to to remove the adhesive? Which is the proper way?
Whats a poor old guy to do?? JIm
jjrbus is offline   Reply With Quote
Old 04-27-2013, 05:52 PM   #18
Rewards Points: 918
This is simple-do a test.
Mix up a pound of thinset and set a few tiles on the concrete. Work the thinset well into the concrete and burn it onto the back of the tile. Then come back in 2 days and pry them off and see what you have.
Old 05-03-2013, 07:31 AM   #19
Rewards Points: 280
Good advice, so I go to the big box store and there are several different types of thinset! Which one?
So I quit, I am in over my head. I called a highly recommended tile guy to give me an estimate. Some times you just have to bite the bullet. I have had this little bath torn apart for a month, time to get er done.
Thanks for all the input JIm
The Following User Says Thank You to jjrbus For This Useful Post:
oh'mike (05-03-2013)
Removing Laticrete Fortified Thinset kathy3of4 Flooring 4 02-05-2013 10:55 AM
removing thinset from old wood floor annskigirl Flooring 1 05-21-2011 06:41 AM
removing thinset j dorgan Flooring 1 06-18-2010 04:00 PM
Removing Thinset from Badly Installed Tile bobbygarafolo Tiling, ceramics, marble 2 04-21-2010 02:29 PM
Removing old thinset from subfloor gburg3 Flooring 3 12-15-2008 08:59 PM
