Removing Thin Set From Back Of Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 05-30-2009, 12:47 PM   #1
removing thin set from back of tile
Is there any way to get the old thinset off the back of ceramic tile? I had a couple of pieces that just popped loose (tile has been there several years). I've had no luck finding anything even close to the same size/pattern. I can't replace them without getting rid of the old stuff as they'll be too high. Any ideas would be greatly appreciated.
Thanks.
Tralf is offline   Reply With Quote
Old 05-30-2009, 06:52 PM   #2
LeviDIY's Avatar
Rewards Points: 252
Our bathroom baseboards were tile - matching the floor tiles, and we weren't redoing the floor, just the walls and everything else, so we popped the baseboards off and had to get the thinset off them in order to get em back on... only thing we found that worked was a hammer, strong putty knife and a lot of elbow grease and patience.
LeviDIY is offline   Reply With Quote
Old 05-30-2009, 08:37 PM   #3
try a small puddy knife 1 1/2 inch, sander with a heavy grit.
your better off cleaning the loose mud off the back with the puddy knife.
Then use sub floor glue, ie liquid nails, pl 400, etc
liberally apply the glue to the tile mostly in the areas with no or little mud.
Attach the tile to the floor in the very exact orientation that it came up in.
Make sure the floor and tile are clean and clear of any loose material, don't be afraid to use a sponge to clean the tile and floor.
Use a bucket with water to hold the tile in place for a day or two.
Subfloor glue takes a few days to dry.
howdydode is offline   Reply With Quote
Old 05-31-2009, 10:42 AM   #4
Thanks LeviDIY and howdydode. I'm going to start with the putty knife and some gentle taps with a hammer (on the putty knife, not the tile).
Many thanks for your ideas.
Old 05-31-2009, 11:25 AM   #5
A while back I chipped some off with a flat screw driver and scrubed the rest off in the sink.
bkeech is offline   Reply With Quote
Can I install mesh back mosaic tile directly to primed drywall jenrao9991 Tiling, ceramics, marble 5 03-17-2009 06:08 PM
Removing concrete poured over tile in basement nkjetman Building & Construction 6 01-31-2009 04:55 PM
Removing Excess (dried) Thin Set wshouse Flooring 18 07-16-2008 11:38 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
